Old October 17th, 2005, 15:27
asatxj's Avatar
asatxj asatxj is offline
Front drive shafts
Are the front drive shafts the same regardless of xfer case? I have a np242 in my DD and my parts vehicle has a np231. If they interchange I'll keep it as a spare. If not I'll sell it.
thanks
Old October 17th, 2005, 15:33
XgeekstarX's Avatar
XgeekstarX XgeekstarX is offline
Re: Front drive shafts
i don't know for sure, but it's definitely worth keeping as a spare.
Old October 17th, 2005, 15:46
langer1's Avatar
langer1 langer1 is offline
Ever hear of a tape measure?
Old October 18th, 2005, 03:51
asatxj's Avatar
Yes as a matter of fact I have. But since I work 14 hour days (teach and coach) I have to use every second wisely and thought that MAYBE someone would have tried this already and could say "yes" or "no" and save me working out in the dark with the aforementioned tape measure and a flashlight. Thanks for the help.
Old October 18th, 2005, 06:56
langer1's Avatar
Ask the Autoshop teacher to have someone look it up.
I think the NP 242 is a little shorter.
Old October 18th, 2005, 07:02
ren's Avatar
ren ren is offline
Do you have an auto or manual tranny in your XJ? Are the drive shafts from the same type of set-up ( auto/ manual)? If they are from different tranny set-ups, then, no, they will not interchange. If they are both from an auto set-up, they should have a difference of about 1 1/2" in length. The manual driveshafts are almost 4" inches different in length from the auto d/s.
Old October 18th, 2005, 13:00
asatxj's Avatar
At last an intelligent answer! Ren both are Auto trans Both front ends were the same. only difference is the xcase.
Old October 19th, 2005, 20:07
ren's Avatar
ren ren is offline
The front D/S will fit with no trouble, the REAR D/S is where you will find the biggest differences in length. Auto to auto, manual to manual, the front D/S are the same regardless of 231/242 X-case. The rear shafts will vary because of the length of the rear X-case section. I should have said that the first time around. Sorry about that.
Ren
Front suspension geometry...lets get in depth... Willis Advanced Fabrication and Engineering 114 September 1st, 2005 01:47
'85 XJ Wagoneer CV front shafts barillms OEM Tech Discussion 6 July 5th, 2005 08:06
Is A Long Travel Front Drive Shaft Needed? MontanaXJ Modified Tech Discussion 5 March 5th, 2005 16:50
Front Drive Shaft problem, need help. falcon556 OEM Tech Discussion 7 December 30th, 2004 21:24
Front and rear output shafts RichP Modified Tech Discussion 2 May 15th, 2004 23:21
