99' XJ Sport 4dr
bgolum
Jacksonville, FL
White w/115K miles
Modifications include:
Rubicon Express Extreme Duty 5.5" lift (Drop Brackets - Steering geometry is stock)
5 - 33X12.5X15' Goodyear Wrangler MTRs
mounted on 15'x 10' rims
JKS Quick Disconnects
High Pinion D30 front axle
Ford 8.8 rear axle w/disc brakes
MORE Wheel spacers to bring Ford 8.8 track back out to match stock
MORE Ford 8.8 install kit (includes e-brake cables, u-bolts, shock mounts)
4.88 gears (installed by Jon Jacobs)
JB Conversions Heavy duty slip yoke eliminator (SYE)
Custom welded on shock mount skids (rear)
Custom welded on control arm skids (front)
Tom Wood's Rear Drive Shaft
Factory Gas Tank skid plate
Factory Transfer case skid plate
Skid Row Automotive Engine skid plate
Rocky Road Rockrails
Terraliner Off Road Custom Front Winch Bumper
WARN 9.5xp Winch
Off Road Only X-line synthetic winch rope
Rusty's Air Tube
K&N 6x9 Conical air filter
Challenger Performance Alumi-flex tie rod
ARB air lockers front and rear
ARB Compressor mounted in rear
WARN Differential Skid for D30
Optima Red Top Battery
Magnaflow Muffler
Uniden Pro538 CB radio
Firestik Firefly 3 ft antenna
Garvin Industries Off Road roof rack (Hi-lift mount, spare tire mount, axe & shovel mount)
72" Hi-Lift
Factory Trailer hitch
Recovery Kit - including D rings, 30ft 3/8 G70 chain, tree saver, tow strap
I'll even throw in my spares:
Drag link
Tie rod
D30 axle shafts
U-joints for both drive shaft and front axle
Front has been trimmed to fit 35s, rear would need to be trimmed to fit 35s(never got around to it).
Asking $9,900 for everything listed.
