Old February 17th, 2005, 05:19
COXJ's Avatar
COXJ COXJ is offline
NAXJA Member #989
inline fuel check valve
were can i find a check valve to keep my fuel rail presurized so i dont have to put up with all the cranking every time i want to start the jeep after it has sat for a wile. i looked threw my jegs catalog but came up with no such luck. anyone?
Will
Old February 17th, 2005, 16:14
RCP Phx RCP Phx is offline
Re: inline fuel check valve
Thats already built into the system,you need to find the real problem and fix that!
Fuel Pump Questions?? BIGSLVRXJ OEM Tech Discussion 8 August 30th, 2004 18:32
Headscratcher: Fuel Leak LiveWire Jeeper OEM Tech Discussion 7 August 14th, 2004 09:45
Replacement Fuel Tank...Plastic or Metal??? csr_011 OEM Tech Discussion 11 July 29th, 2004 11:59
Fuel Pump or WHAT ?? geepers OEM Tech Discussion 4 February 17th, 2004 07:53
What to do with EGR valve and fuel pressure indy89xj OEM Tech Discussion 0 September 20th, 2003 00:01
