Built jeep part-out!!! (axles, suspension, tires, etc...)
foxwar71
Foxboro, MA
Built Dana 30 front axle - $1300
-Non disconnect HP housing
-1/4” heavy duty LCA mounts
-RE heavy duty PS UCA mount
-WJ UCA bushing on DS
-Boxed and reinforced coil buckets with sliders built into the front of them
-3” raised bumpstop pad built into lower coil buckets
-Custom heavy duty coil retainers with Grade 8 bolts
-1/4” Inner C gussets
-4.56 gears
-RuffStuff diff cover
-Lubelocker diff cover gasket
-297 shafts with newer Spicer 760’s and full circle clips
-WJ knuckles with JKS spacers welded on
-Teeves style calipers clearenced for 15” rims
-Extended Skyjacker SS braided brake lines included
-Tierod/draglink flipped for OTK with Goferit inserts
-JKS tierod and draglink with HD lifetime TRW TRE’s and RHD draglink piece for proper OTK
-Skyjacker drop pitman arm
-Relocated, boxed, and gusseted trackbar mount that ties into the UCA mount
-Custom trackbar made out of 1.5” OD .250” wall DOM, 2” Johnny Joint at one end and a 2” superride bushing (modded for 1/2” thru bolt) at the other end. Setup with RH and LH shanks for easy adjustablitity
-Spare parts included
-complete set of 297 shafts with BRAND NEW Spicer 760’s and full circle clips
-2 spare correct hubs
-BRAND NEW upper and lower WJ balljoint with hardware
-Spare yoke with extra straps/bolts
-All 4 BRAND NEW TRE’s
-Box of tons of spare bolts (hub mounting bolts, axle hub nuts and washers, etc)
-Any other D30 parts I can find
All the WJ related stuff and such only have a couple of thousand miles, u-joints and brakes only have a couple of hundred miles. Everything is in great working condition. Axle comes complete with everything needed to be swapped in; brakes, steering, brackets etc.
Built Chysler 8.25 rear axle - $800
-Factory 1999 housing
-29 spline
-4.56 gears
-Powertrax No-Slip locker
-Alloy shafts
-RuffStuff diff cover with custom pink middle finger
-Extended Skyjacker SS braided brake line included
-E-brake cables included
-Includes spare stock shaft
Skyjacker midarm subframe setup - $500
-Complete three piece subframe assembly
-Crossmember notched from more driveshaft clearence/droop
-LCA’s have 2.5” Johnny Joints with greaseable bolts at both ends
-UCA’s have 2” Johnny Joints with greaseable bolts at frame side, factory-style cup mount at the axle side to work with stock/stock-style D30 UCA bushing mounts
-I loved this setup and found it to work very well, the rear portion of the subframe does a great job of sliding on rocks if you encounter any big enough. It can flex enough to max out the shocks and unseat a coil. Great compromise to longarms while in my honest opinion being better then regular drop brackets
Skyjacker HD 6/6.5” rear leaf springs - $200
-Good shape, don’t sag at all even with all tools/spares loaded up
Skyjacker HD 8” front coil springs - $100
-Good shape, don’t sag at all even with a beefy front winch bumper
Rubicon Express HD trackbar bracket and brace - $100
-Great shape, only a couple of months old
-I’ll even included all Grade 8 mounting bolts
-Factory stamped sheetmetal upper mounting tab that goes thru the framerail on the bracket has been ditched and replaced with a ¼” thick piece with Grade 8 bolts welded on
Skyjacker 6-8” Hydro shocks (all 5) - $40
-2 fronts, 2 rears
-All bushings seem good and shocks are in working order
-spare front shock and spare boot included
Stock swaybar with Skyjacker 6-8” disconnects - $75
-Good shape, I stopped running a swaybar a long time ago so its seen little use
-Includes mounting brackets and bushings
-Removable pins have a small piece of rubber hose on them to reduce rattling noise
Rusty’s Offroad rockrails - $175
-Great shape, just some scraps and such, could use a fresh coat of paint
-Rear mounting brackets also reinforce the leaf spring mount
Super heavy duty rear storage setup - $125
-goes from the rear seat to the hatch and across from side to side
-Super heavy duty pullout drawer with double ball bearing tracks on each side (each one is rated for 200#, I had no problem filling it with all my tools and everything needed on the trail)
-Built from quailty plywood and hardwood, not cheap crap
-Sides flip up for more storage area, perfect for all spare fluids/straps
-Hidden area behind rear seat perfect for storing spare axle shafts and such
-Hi-lift mounts on top of the box
(5) 35x12.50xR15 Mickey Thompson Baja Claw radials - $500
-2 at 60-75%, 2 at 30-40%, 1 at 40%
-Mounted on (4) 15”x8” 10 spoke black steelie rims with 4” of B.S.
-Spare mounted on 15”x8” soft 8 black steelie rim with 4” of B.S.
-Also included is a 6th Baja Claw that has a small hole in the sidewall that could be vulcanized/tubed
(3) American Racing Outlaw II rims - $50 each/all three for $100/all three and tire for $150
-15”x10” with 3/3.5” of B.S.
-One rim has a 35x12.50xR15 Goodyear MTR mounted on it; very little tread left, spare condition
Dayton 6,000# winch - $200
-Brand new, never even unspooled
-Includes cable, hook, roller fairhead, controller, battery cables with quick disconnect plug
-Mounted on removeable receiver hitch mount
PACKAGE DEALS!!!!!
-Front & rear axles for $1800
-Axles, trackbar bracket/brace, subframe, springs, shocks, and swaybar for $2500
-Ask about other combos and deals
Not interested in shipping anything at this time, all prices are BEST OFFER, feel free to PM any questions/offers. for trades, i could be interested in some 37-40" tires, hp60/14b parts, maybe other stuff for my 1ton build
willing to just sell the spare shafts?
no, sorry bob
Does the front have a locker??
not anymore
will you hold the winch for me, and i'll make it out there in a week or two?
deal :thumbup:
Oh yeah, are you willing to trade for anything...
i could be interested in some 37-40" tires, hp60/14b parts, maybe other stuff for my 1ton build :dunno:
i jsut did a quick edit on the package prices; 1800 for the axles, 2500 for the axles and other junk
PM sent about trades for axles. Sorry I didn't see that you had said you'd trade for stuff for you're one ton build.
Sorry Johnny, i wanna sell the trackbar with the axle since its setup to match the rest of the steering and the pitman arm. if the buyer of the axle doesnt want it, ill let you know.
I can also build you one if you want, i got some 1.5" DOM kicking around and some bushings :dunno:
I misread your post about the trackbar bracket.... I just need to build a new one myself, I was just being lazy
