AUX fan not coming ON in a 91 XJ
b4wheelnxj
VA BEACH VA
ok well i just bought this jeep about a month ago saw the aux had zip ties hold it in place didnt think about them breaking and the fan fallin to the motor we ll got a little messed up well i went and pulled the new clips from the junkyard and hooked it back up well i get nothing now so i went back to the bone yard and got a later model fan only one they had i have the newer one 10 blade in my 91 NO POWER to the fan at all were is the relay at and were should i start at need to get it working ac cant use and going wheeln in 2 weeks need the heat issue fix any takers
The relay(No. 1) and fuse(No. F4) are both in the PDC(power distribution center).
The PDC is just behind the battery.
b4wheelnxj said:
well i read that in this forum before and i turned on the ac and it didnt work tis the reason for the post thx tho i did check that
also if the A/C is not charged it will not click on..just throwing out info for ya :laugh3:
To test just the fan, you could try the following;
1. remove relay
2. confirm you have a good fuse, then power on contact 30 (PDC)
3. short contacts 30 and 87. Fan should turn on.
