pictures of cps loc.
jimmyc75
pittsburgh pa
question i am going to replace my cps tommorow and was wondering if anybody had any picture (not drawings) of where the cps is in the bell housing? also any pointers would be appriciated!!
87 jeep cherokee
4.0 auto
in case anyone is wondering why i have no spark and the coil and module are both good.
thanks
87 jeep cherokee
4.0 auto
thanks
It's on top drivers side and it's easily reachable with a lot of extensions and a swivel or two. You can find it by following hte wire from the top, get a general idea and than find it from the bottom. Oh yeah, don't drop those bolts inside.
I dropped one once...never did find it. I had to replace it.
Just imagine where your foot sits on the gas pedal....the CPS will be right on the other side of the firewall at your toes. Right where the engine and trans bolt together.
It's at the top left - you're looking at it from the rear.
The tranny was dropped a few inches for this photo
Or go here: http://www.yuccaman.com/jeep/cps.html
I have replaced the cps bolts many of times and this is the best thing i can give is put some heavy greese or vasoline on the inside of the socket to hold the bolt in the socket while your lining it up this will keep it from dropping out
I bought a sheet of Magnetic rubber and put a piece in every socket I own.
