- Nashville, TN
Pulled the XJ out of storage today. Spent some time at the junkyard this morning on 40% off holiday weekend and picked up some brackets and braces for the front end that I though were probably damaged in the rollover.
Pulled it out and set about taking the old damages parts off and reinstalling the replacements to see just how out of whack things are. Really not as bad as I thought. I got things kind of lined up, and was pretty pleased when the Jeep fired right up.
I was able to get the door panels off the two rear doors and got all 4 to open now. I also took the rear hatch cover off the inside and manually jiggled the latch and got it open also.
The way that XJ prices are right now, it may be just as cheap to cut it and cage it. I stopped by 4WP Showroom in Nashville and got 2 leads for shops that do custom cages in Murfreesboro.
If I choose not to cage it I'm going to strip it and crush it, so I decided to cut both passenger side doors down, just to see what it might look like.
Not only did I get the needed XJ brackets, there are a surprising amount of Commanders in the yards - I found 4 - and I got a new passenger side tail light housing that doesn't leak, got new rear door seals that don't droop, and a BRAND NEW drivers side headlight housing. All told, for all the XK and XJ stuff I was into it maybe $75.
Here she is in the sunlight again:
[/url]Untitled by Dirk DeYoung, on Flickr[/IMG]
Here is the "half-door" project cut (look how fouled up that B-pillar is):
