Want 1-2in lift - leaf vs spacer/shackles
SailorDan
San Diego, CA
I have a stock '98 XJ being pressed into daily driver duties that is in bad need of new leaf springs (still wearing the originals:shocked:). I'm assuming it could also do with new coils in front.
I'd like to get a small lift out of the replacement, but it looks like anything under 3" is usually a spacer/shackle solution. I also want to stay under 2" want to avoid any driveline issues right now - all bets off later on.
Since I need new springs anyway, is there a package that will give me a little bit of lift over stock?
Is there any reason to avoid a shackle/spacer setup?
Thanks for the help - Dan
Spacers are fine for the front, for the rear I would recommend doing a "bastard" pack. There is nothing wrong with doing shackles in the rear.
Extended shackles on stock leaf springs aggravates the stock leaf springs tendency to sag and then invert.
A bastard pack is low cost and effective. If you buy an add-a-leaf, be sure to buy a full length leaf, the short overload leaf AAL types are very rough riding.
Coils spring spacers are fine, if the old coils still measure to stock specifications, they do not need replacement.
Pm me. I’ve got used old man emu coils that gave me about 1.5” in Oceanside. Then I used upcountry leafs that also gave me about that in the rear, but I cut those up. I loved that combo.
Thanks for the input. I might just stay stock for now and go big once instead of incrementally getting to where I want.
ljobbins - thanks for the offer - I'll think about it and PM you later.
