WANTED- Blue Ox flat tow hitch
Hey Mr. Billl, is your pops dead set on a Blue Ox hitch or will a StowMaster 5000 work for him? Here's what I have:
The hitch with cover
Set of base plates off of a Cherokee
Mounting brackets for the hitch to the base plates
What is needed:
Safety cables
Chunk of heavy angle steel drilled to bolt to the base plates and then the mounting brackets bolted to the angle.
Used the hitch on my old Cherokee but sold the jeep and kept the hitch.
Let me know if he's interested.
What is needed:
Safety cables
He is interested in the Blue Ox as his jeep already has the Blue Ox brackets on it , but I will run this by him. Thx for the response 👍🏿
He can use other brands of tow bars, adaptors are available to use most any baseplate with any towbar.
I have used a Roadmaster Stowmaster, the type of tow bar that folds up and stays on the Jeep, for a 100,000 miles of towing.
Most RVs today use a tow bar that stays on the back of the tow vehicle's rear hitch.
https://www.etrailer.com/faq-towing-a-vehicle-overview.aspx
Thank you👍🏿 I will pass this info on to him
