Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > NorthWest Chapter
NorthWest Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old August 14th, 2007, 21:59
cleatus92's Avatar
cleatus92 cleatus92 is offline
Unhappy HELP I've screwed up my Jeep
So I was fininshing up a lengthy repair job on my jeep, got it all back together, and it started leaking at the rear tranny line coupling with the quick clips. By the way I love my Y-link but what a bitch to work around!!
Anyway I pulled the coupling And removed the tranny line and found a small peice of the previous broken quik clip in there. So I removed it and began to replace the coupling back into the tranny. This is where my fun began, I got a couple of threads in by hand and figured sweet its started lets tighten her down. Right? Wrong, I somehow in my apparent hastiness to go out and run my new 33's I cross threaded that steel coupling into the aluminum tranny housing. Now I have no reachable threads. Anyone ever screw this up besides me?? If so any fixes possible without pulling the tranny again? I'm thinking tapping it with a pipe tap and a threaded bung. Is there a longer steel coupling out there that would reach the threads. I really don't want to pull the tranny again!!!
Anyhow thanks, and any Info or HELP is appreciated.
Cleatus92
Old August 14th, 2007, 22:05
CanMan's Avatar
CanMan CanMan is offline
Re: HELP I've screwed up my Jeep
Thats no good Trevor.
I would try to tap it first, thread in a tube adapter, and run a rubber hose between the two.
If that doesn't work, might have to pull it again, and have a aluminum bung welded on the outside. Unless it can be reached with the belly pan on.
Old August 14th, 2007, 22:36
Boxil's Avatar
Boxil Boxil is offline
Trevor that sucks man. i've got pipe taps but sorry that none of them would fit your situation. all i've got are for our big pipe. 1.5" and bigger. hope it works out for ya.
mud1059's Avatar
mud1059 mud1059 is offline
helicoil. I think it's how it's spelled. I had to use it on a head bolt on my first 22r (aluminum block) rebuild. They sell it at NAPA I know and most others I'd figure.
Old August 16th, 2007, 12:02
Boxil's Avatar
so Trevor did ya get it fixed? whats the update?
Old August 16th, 2007, 14:00
cleatus92's Avatar
Not fixed yet. Working out a couple different options tonite. Looks like I've got to pull the Y-link.
Old August 16th, 2007, 22:53
cleatus92's Avatar
Well I got it fixed!!! With the help of Napa Guy AKA Dad. He drilled out a 14mm bolt and we tapped it to accept a hose fitting. We then cut down the drilled out bolt to .9110in, teflon sealed the hose fitting into the bolt, threw on a o-ring and caefully tightened it down. we also replaced a section of the metal trans line with rubber transmission oil cooler line and hose clamps. Thus far no leaks and works like a champ. Oh and finally got to drive on my new Trxus 33's. Awesome. I'll be wheeling tommorow evening and then Naches on labor day weekend.
Cleatus92
Trevor
Old August 16th, 2007, 23:00
CanMan's Avatar
Glad to hear you got it fixed, now you can wheel again.
Old June 8th, 2019, 22:37
SmokeyTheRedXJ SmokeyTheRedXJ is offline
Know this is an old thread but guess what just did it today I broke the top the top left portion off my port could you post some pictures
Am i screwed?????? Jeep9717 Modified Tech Discussion 27 June 27th, 2007 20:13
I screwed up and need some help (NSS) white99z OEM Tech Discussion 4 May 20th, 2007 21:11
well i think im screwed xDUMPTRUCKx OEM Tech Discussion 16 May 21st, 2005 15:28
am i getting screwed? madcrazy_lp OEM Tech Discussion 6 April 16th, 2005 09:56
