Old December 27th, 2007, 16:34
GhostDakota's Avatar
GhostDakota GhostDakota is offline
Custom Snorkel Type Intakes (Cowl)
I had an ARB on my last XJ and it worked nice, but costs a wee bit. I've been looking at doing a "HMMWV" type setup on my cowl. I don't want anything something as large as their setup, but an XJ sized variant of it. I'd ready to remove my airbox, cut holes, and get to work I have a good idea of what I'd like to do, but I would love to see your similar setups. Post up! Thanks all!
Old December 28th, 2007, 06:18
Re: Custom Snorkel Type Intakes (Cowl)
Anyone done this? I'm sure I am not the first..
Old December 28th, 2007, 06:26
JNickel101's Avatar
JNickel101 JNickel101 is offline
I have no idea what you're even talking about....?
Old December 28th, 2007, 06:43
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
I think he wants a Humvee styled "mushroom head"
Old December 28th, 2007, 06:55
1985xjlaredo's Avatar
1985xjlaredo 1985xjlaredo is offline
What is this swahili
JNickel101's Avatar
I'll have to go look at some of the Humvee's here....
How much ya willing to pay for one if I happen to aquire one? LOL...
Old December 28th, 2007, 07:02
Kejtar's Avatar
PostMaster General
So to further clarify: we're talking about the "smoke stack" on the passenger side?
Old December 28th, 2007, 07:23
That is correct. It doesn't need to be that high, but that's the general concept of what I want to do. Maybe only 3-12" off the hood line, thinner "stack", and smaller top. My snorkel was cool, but I want to do something different this go around.
Basically, I will be routing a tube from the intake, into the cowl. I'll then have a hole for the tube/stack to pass through and then a filter element inside that I can change out if required. Same concept as a snorkel, just a different type of setup/look.
Here's one on a TJ:
Old December 28th, 2007, 07:28
Kejtar's Avatar
PostMaster General
More pics here.
Old December 28th, 2007, 07:34
splitz's Avatar
splitz splitz is offline
Personally I love the H1, so I remember looking for ways to have the intake and front clip and I saw someone with the mushroom intake on thier XJ...just can't remember where.
Funny thing is when I was quickly searching for those threads I found this:
Old December 28th, 2007, 08:00
That's like a Landrunner Cherokee.. lol.. They have Landrunner TJ's and such (wider body, more slots, etc.), but haven't seen a similar XJ 'til now.
Old December 28th, 2007, 11:07
bandit455's Avatar
bandit455 bandit455 is offline
Here's one on a TJ:
This is an awesome idea
Has anyone done this on an xj, the hard part would be routing it over to the passenger side so it isnt directly in frontof u.
Old December 28th, 2007, 11:22
Thanks! lol. My plan is to pull the airbox assembly completely, spin the intake tube around on the throttle body, and run it to the passenger side, and into the cowl area. This would keep it out of the driver side, rather easy too. I just have to be careful of the heater core and such.
You have to have a rain and splash guard as well, which is pretty simple to do if you look at the design behind the Humvee setups.
Old December 28th, 2007, 11:28
bandit455's Avatar
good plan
Old December 28th, 2007, 18:02
bandit455's Avatar
Has anyone else ever done this?
I have seen the guys that run it up to the cowl vernt but the issue with that is that the second u go i over ur hood u will get mud pushed down into the filter. that is why I like o having the covered filter above the hood
CV type or spicer type '91XJ Laredo rebuilt Modified Tech Discussion 0 March 21st, 2006 05:11
cone filter & snorkel custom $6 airbox jeepnuts311 Modified Tech Discussion 6 February 8th, 2006 19:07
Custom Snorkel HaZakated Modified Tech Discussion 19 April 13th, 2005 13:05
XJ99's Custom Snorkel Set-up XJ99 Modified Tech Discussion 0 April 12th, 2005 06:57
Air intakes,which one laredo Modified Tech Discussion 6 September 13th, 2003 06:20
