Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > The Daily Driver
The Daily Driver A technical forum for the ride that gets you to work every day.
Old September 27th, 2018, 18:58
amfw amfw is offline
Changed battery cables, broke ecu ground...
Did my battery cables yesterday and in the process broke the ground on the block for the ecu. Crimped a new eyelet on and replaced, but it was a bit of a stretch to get it on the stud. Jeep starts very nicely and runs great, except there have been a couple times it completely shuts off for a second and then continues as if nothing happened. I'm thinking I need to splice in a new short length of wire and rr ground the ecu and obviously go through all the other ground points that were touched. Anything else this could be that I should be looking at? '98 BTW
Sent from my Pixel 2 XL using Tapatalk
Old September 27th, 2018, 19:15
smccollamjr smccollamjr is offline
Id start with exactly what youre suggesting and double check the cables you just put in.
Old September 28th, 2018, 05:14
Re: Changed battery cables, broke ecu ground...
Yeah, figure that's the best course (it's the most obvious) just didn't know if it might be something else. Now I just need the rain to stop.😎
Rate This Thread:
Battery cables thesteveyo OEM Tech Discussion 12 August 29th, 2015 14:54
Battery Cables cartbart Modified Tech Discussion 8 June 20th, 2015 22:05
Battery cables/ground? ZenDragon OEM Tech Discussion 1 November 29th, 2012 14:31
Battery Cables Eureka Jeep OEM Tech Discussion 18 March 23rd, 2007 23:09
2/0 battery cables ZmOz For Sale: Private Party Only. XJ ITEMS ONLY 1 September 1st, 2004 19:37
