NP231 "shift shaft seal" replacement question
Jeff in VA
<---respect
Richmond, VA
Has anyone replaced this seal? It's the one where the shift rod selector goes thru the side of the case. Mine's leaking, and I need to fix it. Is it a dealer-only item (part # is 8350 4727) or could I source it locally? Any tips on replacement?
TIA,
Jeff
Well, apparently DCX must have decided that those seals will never leak....they discontinued the part # with no replacement, and the dealership doesn't show ANY in national inventory (WTF?) He said to try NAPA, which I did, and they weren't any help.
Surely this little seal is available somewhere, yes?
Jeff
Getting a seal or any seal should be no problem, there is the I.D. inner diameter where the shaft passes through, the O.D. or the outer dia of the seal where it would press into the case, and the thickness.
A cheap dial caliper is usefull to anyone in this situation. Or just pull the seal and take it to a parts store, even though I have been in an Advance and Autozone the same day and no one in the store knew how to use a book to look up the seal. Idiots...
Anyhow it is easily do-able. Or stop in a transmission shop, they'll likely help you just so you'd come back for a trans job, find a private owned shop..they tend to be friendlier to parts hunters/do it yourselfers than franchises.
Well, it helps if you're asking for the correct part number :)looser: ) Another look at the IPL I have shows the correct #'s for what I need are:
J813 0853 seal
J813 0854 O-ring
Both in stock at the local stealership, about $1.50 each. I'ma picking them up after work today....
Thanks all,
Jeff
