The Daily Driver A technical forum for the ride that gets you to work every day. |
Thread Tools | Rate Thread | Display Modes |
Best gasket kit for a 4.0?
Redoing all gaskets on my 98 55K mile 4.0
obviously I want the best of the best this engine will be going into my 2 door where it was originally but after I decide to do a engine swap I’ll be buying a body to restore for my girlfriend & that Jeep will get the whole drive train while mine is under the knife for 05+ superduty axles & either a LS or diesel swap ![]() Sent from my iPhone using Tapatalk Pro |
#2
Re: Best gasket kit for a 4.0?
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ 01 Sport, 4.6L Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/ 1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
red gasket maker ok with rubber pan gasket? | SeansXJ | OEM Tech Discussion | 12 | May 15th, 2009 14:11 |
Rear Main seal, 1 piece oil pan gasket and valve cover gasket | KingOfTheHill | OEM Tech Discussion | 28 | October 8th, 2008 00:39 |
v/c gasket | rufus_1111 | OEM Tech Discussion | 1 | July 21st, 2008 15:47 |
gasket set | green95xj | OEM Tech Discussion | 4 | June 1st, 2008 10:51 |
Do I need both a thermostat gasket and thermostat housing gasket? | 90Pioneer | OEM Tech Discussion | 1 | March 5th, 2007 17:45 |
