Coils for Rear of your XJ, ZJ coils front and rear, TJ coils front and rear, $40, AZ
I have lots of coils sitting around Im not using..They would be great for the rear of an XJ after you 4-link it. no more leafs to worry about.
ZJ I6 stock coils front and rear
TJ stock coils front and rear.
Ill get measurements if you need them, The ZJ rears are a good height for a rear coil conversion on an XJ. I mounted them up but decided to cut my frame off and try some air shocks. The TJ fronts would be the next step taller and the ZJ fronts mounted under the XJ frame in the back might be too tall, even for me :D
Im in North Tucsion Arizona.
$40 a pair, or $60 and you can have all 8 coils.. you can have my coil mounts too..
I painted the Zj rears red.
ZJ rear coil pics.
download.php
download.php
download.php
Dont need them any more:
download.php
Re: Coils for Rear of your XJ, ZJ coils front and rear, TJ coils front and rear, $40, AZ
ZJ rears are 14in
ZJ fronts are 18in
TJ fronts are 17in
TJ rears (pig tails both ends) 12in.
