OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Replacement Cylinder Head Question
Anybody have any experience with aftermarket 4.0 heads. I need one for my 2000 XJ. I won't used a reconditoned one because of the poor history of them, unless it was from an '04-06 engine. Hesco is WAY TOO expensive. I was looking at clearwater cylinder heads or Alabama cylinder heads.
ANY experience with either or another company. |
#2
Re: Replacement Cylinder Head Question
If you have studied the threads, you know that you can also use an older head. '98 or earlier. I got one for $50 for my 2000. People have posted results for clearwater and alabama. As a matter of fact, I see a thread below about Alabama heads.
#3
Reports from the field are good from ACH - I'm not sure if they're new or inspected/remanned, tho.
You can use 2002-2007 WJ/WK/TJ heads (#0331) as a direct replacement. If you go with an earlier head, you may have a bit more work - the #0630 heads (1996-2000) have the same size exhaust port exits, but the #7120 (1991-1995) are larger and will require a block-off plate so the exhaust won't leak at the primaries. Information on that can be found here, I think someone was making "#0630 to #7120" adapter kits that should work with the #0331 heads as well. The only true "aftermarket" head I can confirm as new production is the aluminum job being sold by HESCO and Patriot Performance - which is probably the same head from both shops (and I'd like to know who's casting them and how they got the idea - we were bashing this around on the "Strokers" egroup back around 2001, then I took the info gathered to Russ Flagle at Indy Cylinder Heads...) |
#4
Alabama's are new re-enforced castings of the 0331 so it's direct fit.
#5
I talked to he guys at ACH at length about their heads before I ordered one for my '01. I ran mine pretty hard out to Moab and back shortly after install an had no issues. Direct bolt on and a good quality piece for the money.
#6
I'd always thought that production life of the thing was 21 years - 1987-2007. I guess it was an even twenty. Pity - it deserved far more. Look how long the SBChevvy, Ford Windsor, and Chrysler LA-block were around! |
#8
Pthargh. I have got to finish my head collection. Anyone have a warped/cracked 7120 or 0331 (or two) lying about anywhere near San Jose, CA?
#10
winterbeater is right about the 0630 being near identical to the 7120. I'm willing to give you the 00 cast 0331 I pulled off the 01. It has at least 3 valves that don't seal. I don't see the common crack on top b/t 3 and 4, but there are hair-line cracks that emanate from 3 of the coolant port triangles, so I could see the possibility of a HG not being able to stop coolant from getting in the cylinder or gas-air mixture in the coolant. I'm opposite coast in MD. . .
Oh yeah, I bought a J&W thicker cast 0331 head for the 01 for $369 shipped(no core charge--they don't recon, 2 yr warranty). Odessa also had one for $375 w/ a 1 yr warranty, and Clearwater had them for $400 w/ a 5 yr warranty. Last edited by gradon; January 12th, 2010 at 22:30. |
#11
Oddessa($369) is the same place as Clearwater($425)(Oddessa is the ebay company) I asked the guy what the difference was and he said they are the same head, just the CCH one has a 5 yr warranty vs 2yrs from Oddessa. Alabama uses all new parts, the other places use old valves and springs. Which would you choose? |
#13
www.citymotorsupply.com is reasonably priced. me and my buddies have bought 4 different heads from them.
#14
I would definitely go all new, it's only $100 more for a new re-enforced head with all new valves, springs, seals, retainers and clips. Come on now that's not even really worth debating is it? But it's your money and ultimately your decision.
#15
It's actually $150 more than the the head from CCH with the 2 year warranty. I do like the idea of all new parts. My friend that works a machine shop said they use used parts all the time. I just gotta figure out how much I want to spend, it's gonna be another $100 for gaskets and head bolts and misc stuff.
Thread Tools | |
Display Modes | |
'99 cylinder head question | mrtosh | OEM Tech Discussion | 6 | January 5th, 2010 15:41 |
Is there a replacement head comparable to Alabama Cylinder Head? | Emerscape | OEM Tech Discussion | 42 | October 19th, 2009 10:10 |
D/FW Cylinder Head Replacement mechanic? | Windrider | Red River Chapter | 5 | May 1st, 2008 20:31 |
Cylinder head install, one more question | Ron Hyslop | OEM Tech Discussion | 11 | October 8th, 2005 06:29 |
Rear cylinder head freeze plug replacement | MJ1990buildup | OEM Tech Discussion | 9 | September 23rd, 2004 19:51 |
