Concrete Foundation Repair (from the outside)
juliediane
United States
I've got a vertical hairline crack that runs the full height of the basement wall and leaks. I understand the only way to properly repair this is to dig down beside the foundation floor preparation Brisbane. What I'm not sure about is what process or products to use from there? I only want to do this once.
I can't locate a backwater valve so I may not have weeping tile.
You can repair the crack but it wont hold until you fix the root of the cause. There are a lot of good solutions for a bad foundation but they are mega expensive.
