    More Information - Join/Renew
The Stupidist Jeep on the Planet
crossmember is done, reinforced with 1/4" plate and rod
also shortned a stock auto frt ds 4.5" to work with the atlas and frt 60
nice work dude... shortening shafts is much easier then I thought it would be
spent the day finish welding in the stiffners damn that was alot of holes, also managed to hit the duty cycle on the welder, also capped of the rockers and primed em
my craptastic welds
capped rocker
finally started adding floor, origanally wanted to do a subframe like vettboy but dont have the room on the drivers side, alot of issues with the atlas driveshaft and gas pedal
less floor
more floor
plenty of clearence at full stuff
I am in the same boat right now, plated most of the uniframe, sending the rig off for cage work in the next week, and once I get it back I gotta put a floor in.
with all the rust I have, it should make for some interesting splatter during the welding process, or should I say interesting welding during the splatter process.
looking forward to seeing how you finish this, as I will be following suit soon enough.
got the floor subframe started. got around the atlas and trans planned out in my head
damn, are you inside my head?
same plan as I started last weekend.
are you planning on having the floor pan above the trans/t-case removable?
and what are your plans for cleaning up inside the the rails? I figured I'd wire wheel them and rattle can them and hope for the best.
there will be a piece above the trans and tcase that is removable so i can pull the shifter off and acsess the top 2 tcase bolts, and i have no plan for the frame rails at the moment
lack of updates was due to a nice trip to Florida, Texas and Louisiana to fistit lots-family, anyways, Floor subframe is now 95% done, tomorow i will add some pieces down the middle to tie em all together(cept the shifter ones ill just have a pices on the side) weekend will include 2x4 crossmember to replace the one under the rear seat or i just might make one from the stick of 2x2 i got left, and ill ass shock mounts and coil retiners for the frt 60 then all it will need is gears lockers and shafts installed
got frt shock mounts done and shocks in, upper mounts im using homemade adapter from Chris and lowers i copied Colin's setup. im only using like 9" of shock travel and the limiting straps let the coil drop out an inch wich was exactly how i wanted
started this morning making a chunk of the pass side spring hanger disapear along with some floor
then made a new piece from 3/16 plate thats also capped on the top and bottom along with being tied into the rear rocker leg
got working on the driver side hanger this morning, tonight after work it will get more steel then its off to the rear hangers
this upcoming weekend should have some pretty good updates too
