Jay3XJ+
- Houston, TX
Front Low pinion Dana 60 Housings only. (King Pin)
One passenger drop, one driver drop
One has had the yoke nut ground for clearance so it will have to be cut out, the housing is in good shape
Chevy Dana 60 knuckles
Dana 60 Caliper Brackets
Dana 60 calipers….good for cores.
1990 Jeep 4.0 block. High miles good core.
1990 4.0 head needs rebuild good core
NP 205 Tansfer case
Dana 300 Transfer case. Torn apart, to rebuild all parts in great shape needs bearings.
1990 NP242 Transfer case 21 spline input
1990 AW4 21 spline output.
Dana 30 high pinion front axle (one piece)
Dana 60 rear housing ok shape not the best.
AW4 and RENIX Jeep Computers
Rear dana 35
Make an offer via PM and I will get back to you as soon as I can. Rather not ship the big stuff but the small stuff is ok.
All of this is located in Katy Texas 77450 ( Houston)
NP 205 Tansfer case
Rear dana 35
