Axles: 8.8, 8.25, HP30, misc other stuff
GoSlowGetStuck
Lafayette, IN
Changed my mind on some things and now I've got some stuff that needs a home.
- Ford 8.8, 31-spline, 4.88 gears, PowerTrax no-slip, Riddler diff cover - however it does need perches, shock mounts, companion flange - $325
- Chrysler 8.25, 29-spline, 3.55 gears, Lock-Right, RuffStuff diff cover, TnT U-bolt eliminators, ZJ disc brakes - $400
- HP Dana 30, 3.55 gears, Aussie locker, RuffStuff diff cover - $300
- Dana 30 bare carrier, 3.73+ ratio - $60
- Dana 30 master install kit - missing a couple shims but has most of them - has all bearings, pinion seal/nut, etc. - $60
- HP Dana 30 4.88 gear set - $100
- Manual tire changer - bolt this sucker to the floor (or don't, but recommended) and break beads and dismount tires with a lot more effort than the guys at your local tire shop - comes with a jug of tire lubricant - $50
- NP231, tag indicates 1988, 21-spline input - $75
- Dana 35 C-clip axle shafts with ABS tone rings - $40
Everything can be delivered to Winterfest, otherwise send me a PM to figure out delivery. Pics of everything below, let me know if you need any additional pictures.
Ford 8.8
Chrysler 8.25
HP 30
Dana 30 3.73 carrier
HP 30 4.88 R&P
Tire changer
NP231
D35 shafts
Package deal on the:
8.8
D30
carrier
install kit
4.88 gears.
JIM.
Jim, sent you a PM.
DoWorkXJ, it is a G2 kit and they are Timken bearings. I will let you know for sure after I talk to Jim.
Nate, I'm sure we can work something out, I'll call you tonight.
Thanks for the interest guys.
