Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old January 16th, 2019, 10:46
old_man's Avatar
old_man old_man is offline
Looking for a vehicle with a wide D44 Rear Axle
Over the years my XJ has evolved. I am running D44's front and rear. The front is a full width axle, while the rear is a normal width XJ D44 running a 2" spacer on each side.
This puts a large strain on the axles and I set out to reduce it. I have a clean D44 housing and I was going to widen it 6 inches to better match the front. The issue is getting replacement axles. I really don't need the super high strength ($$$$) Chromo axles. The standard grade would suffice. The question is... does anybody know of a standard application vehicle that has a wider track? I could match my width to that track or cut down the axles a bit if necessary and could get the axles for probably $175 a piece, or way less from a junk yard, instead of $300+ a piece.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old January 26th, 2019, 05:10
dasbulliwagen's Avatar
dasbulliwagen dasbulliwagen is offline
Re: Looking for a vehicle with a wide D44 Rear Axle
Im not sure on the numbers, but I know a JK Wrangler rear Dana 44 is wider than the XJ.
Old January 26th, 2019, 08:15
old_man's Avatar
I actually scored an empty D44 housing and I am going to widen it. I also found chromo axles that are extra long so you can cut them to length.
I am looking for a D44 carrier for 4.56's with spider gears if anybody has one from an upgrade.
Old January 29th, 2019, 07:16
VAhasnoWAVES VAhasnoWAVES is offline
ford offered the 8.8 in full width.
but id suggest a 9. parts are super common, an aftermarket third is super beefy.
Old November 24th, 2019, 15:37
egon's Avatar
egon egon is offline
Dunlop Slayer
Xterra Offroads and Titans used a 44 rear axle. Xterra's is the same width as a JK, Titan is wider. Should be same guts as a JK 44, I believe Dana called it a "44 Super". Both axles have disc brakes and BIG axle shafts, 6 lug stock though. 6 on 4.5 for the Xterra I believe.
Yeah, yeah, thread necro...
--Matt
"I need you to do some magic" - Andy in PA.
07 X OR | 96 XJ | 86 CJ7 | 85 CTM A30 MOD | 04 F800 | 87 SR800
Boulders - Boats - Bikes
Old November 30th, 2019, 14:26
rockosocko rockosocko is offline
I have a couple of SJ wide-track axles that are out.
One from a '74 J-10, one from a '81 Cherokee, and a set from a '79 Wagoneer, reg track. (But those are 2.72 gears lol)
Would you like me to measure them?
E
Old December 3rd, 2019, 14:09
old_man's Avatar
Thanks anyway. I already started widening mine.
Rate This Thread:
FOR SALE: CJ DANA WIDE TRACK 44 REAR AXLE Gravesdiggerxj For Sale: Private Party Only. XJ ITEMS ONLY 1 April 30th, 2010 08:14
How wide is 8.25 axle? chris420 OEM Tech Discussion 13 December 18th, 2008 21:19
Wide track AMC 20 rear axle swap in...? fuzzydog Modified Tech Discussion 8 November 4th, 2007 22:11
How wide is my rear axle? zfinger OEM Tech Discussion 3 April 17th, 2007 11:31
