XJ_Otto
- Nashville, TN
Near Knoxville, TN
1998 Jeep Cherokee Classic, White
132069 miles and rising (DD)
4.0L
AW4
D30 HP front/ChryCo 8.25 rear
Open/open
Owned since 103xxx at the end of 2008
NEW Firestone Destination LE 235/75R15's on stock alloys @ 129315 miles
Regular Oil Changes
New Spark Plugs, Wires replaced @ 127267 miles
Serpentine @ 112906 miles
Last oil change @ 127219
O2 sensor (rear) replaced around 120000 ish miles (didnt write that one down)
5% tint front to back on the sides (fronts arent perfect)
rear is stock tint
Bought a battery 9-3-2008, have reciept from walmart
A/C works but needs a charge every couple years...works beautifully right now.
Front sway bar frame bushings 12/16/09
Other receipts
Lifted with some kind of budget lift:
Unknown brand front coils, AAL, rear 1" block
4wd Hardware shocks
Skyjacker steering stabilizer
Extended swaybar links
Known issues:
Leaking (dripping) Tranny lines. 70 bucks in parts
Wet (NOT DRIPPING!!!!!!) where rear main is. Im assuming thats what it is)
Front bumper has a scrub from a damn dumpster I rubbed it on after repainting like 3 months ago on the right corner.
Extras:
Matching 5th wheel with no tire
Front winch bumper (in pic below)
CB and antenna (not mounted)
Stock coil springs
Rear Swaybar
New unmounted Currie U-Bolts
1.25" Coil spacers (metal)
Trackbar reloc. bracket
If I can think of anything else Ill add it. Jeep was offroaded a few times...search my name and you'll find the posts of the only times I went. Wooly's once and Windrock once Im 90% sure. I sold off the 31's and winch and was gonna turn it back all the way stock to tow, but Im just gonna get something else. Wouldnt take much to make it awesome again. Ask away. This thing has been great to me and Id drive it across the country tomorrow if I had to.
$4250
Other and better pics, PM me.
Used to be...
Is....
4.0L
AW4
Open/open
Regular Oil Changes
rear is stock tint
Other receipts
4wd Hardware shocks
Known issues:
Extras:
Stock coil springs
Rear Swaybar
$4250
Used to be...
Is....
