Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > SoCal Fest 2018
SoCal Fest 2018 April 27 - 29, 2018 at Calico.
  #31
Old April 1st, 2018, 20:44
blackbox's Avatar
blackbox blackbox is offline
Re: SoCal Fest****GENERAL INFORMATION**** April 27 - 29, 2018, Calico,
I hope is not too late to join, just booked my spot. I may be able to take Fri off and drive there from SD around noon, what is the plan for Fri?
  #32
Old April 7th, 2018, 18:20
waxer's Avatar
waxer waxer is offline
Is there any information on the dinner that is being made available? I see tickets are available for purchase, but there doesn't seem to be any information on what is being served, when it is and where it's located so I know what I am purchasing.
Also, is there any info on the runs and the meeting times/locations for each?
Thanks guys
  #33
Old April 8th, 2018, 07:17
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
As far as dinner goes the plan is for burgers and brats.
As for runs there will be Odessa, and Doran canyons as well as one or two easy to moderate exploitation type runs. As always it is somewhat contingent upon those volunteering to lead runs.
Run start times will be determined by each individual leader. Probably around 8am if previous events are any guide. Usually runs line up along the roadside in the vicinity of the bunkhouse.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
SoCal Chapter VP
  #34
Old April 8th, 2018, 10:12
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
And I would assume dinner will be at the bunkhouse around 6pm? If history repeats itself.
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52lbs of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky 450, Kims 2011 R6, Kims. 99 Toyota Avalon, daily. 97 Miata, Kims.
And everything fits in the garage!
Kill yourself, or die trying!
Originally Posted by mako my day View Post
Johnx is #1
  #35
Old April 16th, 2018, 20:42
chasdb's Avatar
chasdb chasdb is offline
NAXJA Member 3643
I've got a 2 basket propane fired deep fryer I could bring. Fries to go with burgers and chicken nuggets for the kids.
'00XJ Mall Krawler Edition Bishop Buehl 4.7Stroker,241J, Rock Krawler aluminum 3 link, D44hp Yukon air zip, D44 35 spline axles locked by RWKHaus. Stiffners, and brackets by Ruffstuff. High steer-Parts Mike. T&J, fenders+ cage. Bilstein 7100, 35 KM2, OMF Beadlocks, PAC coils, Deaver G9leafs, BrownDog mounts, Currie antirock, PSC hydro
my build
  #36
Old April 18th, 2018, 20:39
Carol.92124's Avatar
Carol.92124 Carol.92124 is offline
Yes, it's MY Jeep =)
Oh my!! Would you be willing to run it, and chase the kids away from the hot oil? Cuz that could work...
GrimmJeeper "The rule of buying things is if you have to ask yourself if it's a good idea or not, it's probably not."
White 98 2Door named "Cali", 4.56s, rear D44 w/Aussie, 31" M/Ts, AJ's SuperRails Rockrails, Custom 4x4 Fab towhooks, JKS discos, 3" "pretested" lift so far--Hey, I'm still working on it!
SoCal Chapter Treasurer
  #37
Old April 18th, 2018, 21:04
chasdb's Avatar
NAXJA Member 3643
Sure, If any kids survive the trail runs I can set up a wire dog kennel around the fryer to keep them from getting crispy.
my build
  #38
Old April 21st, 2018, 20:39
So burgers, brats, french fries (Thanks Charles!), and possibly chicken nuggets... sides usually are salad & potato salad.
  #39
Old April 25th, 2018, 10:01
frijolee frijolee is offline
Is there any kind of schedule planned? I've seen runs at 8 am and dinner at 6 pm but that's it. I assume those are both Saturday?
Since Calico is need to me are trail runs all day kind of events or will it be a couple sessions?
Lunch on the trail Saturday? Assuming DIY but will we be near camp or no?
Any times better or worse to check out Calico itself?
Any evening wheeling Friday or Saturday?
Anything going on Sunday am?
Doesn't need to be elaborate but some basic targets of what and where to meet will help me plan.
  #40
Old April 25th, 2018, 21:53
JohnX's Avatar
Sarge <3 Ben
I might be enticed into a friday evening run.
Generally the saturday runs are all day, bring lunch and lots of water.
Johnx is #1
  #41
Old April 26th, 2018, 12:50
waxer's Avatar
Same here on the Friday night run.... that sounds like fun.
The family and I generally do our own exploring on Saturday, mainly cause the little one doesn't like being tied to the vehicle all day long. But that's our boggle to deal with..
Rate This Thread:
Site #39, available for SoCal Fest 2013 April 26-28, 2013 at Big Bear, CA RWKHausSupply SoCal Fest 2013 0 April 15th, 2013 07:54
Check out the SoCal Fest Forum for SoCal Fest News! Monkey55 SoCal Chapter 47 May 4th, 2012 21:31
Calico in April homebrew SoCal Chapter 28 February 10th, 2010 13:36
