Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Comanche MJ (1985 - 1992)
Jeep Comanche MJ (1985 - 1992) Jeep's Cherokee-based compact pickup technical forum.
Old July 10th, 2019, 10:21
tylergrant2011 tylergrant2011 is offline
Turn Signals and Hazard Lights
On my 87 4.0 for some reason my turn signals and Hazard Lights stopped working. The indicators on the dash also stopped. Any ideas or help where to start?
Thanks
Old July 11th, 2019, 08:55
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Re: Turn Signals and Hazard Lights
cruiser54.com Is where I would start. You might just need to do a ground refresh. I know on my XJ a relay was loose under the dash when I had my issue. That was also a HO, but it was a round silver thing-a-ma-jig.
88 MJ, 4.0, 4wd, 3 pedals, Shortbed.
Mods; ACOS, quick discos, HD tie rod and a bitchin air fresher
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old July 12th, 2019, 04:19
It turned out to be both flashers were bad
no brake lights, turn signals or dash lights bmxdude151 OEM Tech Discussion 6 September 9th, 2013 07:51
Turn Signal Activating Hazard Lights Box kicker South East Chapter 4 April 24th, 2012 19:24
97-01 Marker lights/turn signals $15 JeepCherokeeGuy99 SoCal For Sale 2 September 26th, 2011 18:19
Marker lights, turn signals, DOT H4 Vince OEM Tech Discussion 9 January 17th, 2009 16:00
No reverse lights or brake lights or turn signals... TheHighHeat OEM Tech Discussion 6 October 5th, 2008 15:13
