MrShaft696
- Blue Bell, PA
I had some maintenance items to take care of, and at one point in time during one of my incarnations of lift, some aluminum blocks ended up under the leafs & this is the result. It pretty much crumbled & started to disintegrate into the center bolt.
Changed to steel
The winter took a good toll on everything so I had alot of rust to wire brush and sand, so I touched up the bump stop plates I had made.
Touched up the shock mounts, & the leafs have been beefed up & they are sporting a bunch of s10 main leafs & a overload leaf & its firm & its not bouncy which kind of annoyed me about the other set ups I have ran.
Anyway who cares, but Im ready for nac fest unless something else falls of, breaks or leaks.
Changed to steel
