I'm going to be out there for the Full Size Jeep gathering in Ouray starting tomorrow through the 23rd. My J10 won't be making the trip. I'll be in the XJ. I'm sure I could talk a couple of the FSJ crew into running Black Bear on the 22nd.
OK. My mobile is 423-217-7445. I should have better steering by Monday. Current box and pump are questionable. Swapped the box I used last year over Black Bear and ended up with one that is looser. But it should be resolved by Monday. I am looking at coming down for Friday-Monday trail runs. Black Bear/Tincup/St Elmo. I might could have lockers wired up by Black Bear if it helps. I will plan on renting a room in Montrose or Ouray.
An other thing that kind of sucks now is that all of the commercial "Jeep tour" outfits down there have switched to full-size Dodge pickups with stadium seating in the back, making already narrow trails even more sketchy when you have to get by them.
Meeting at the dirt pull off on south side of ouray. (First uturn across from box canyon entrance ).
Pull chocks at 8. Fj summit and krawlorado are there this weekend someant to get on the trail early.
