Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep CJs and Wranglers > Wrangler YJ, TJ, and LJ (1987 - 2006)
Wrangler YJ, TJ, and LJ (1987 - 2006) Technical forum for the Wrangler YJ, TJ, and LJ Unlimited.
Old August 28th, 2018, 09:38
macgyvr's Avatar
macgyvr macgyvr is offline
NAXJA Member #120
TJ exhaust
A friend of mine needs the entire exhaust for her TJ from the engine to the tail pipe except for the manifold itself.
Anyone got any suggestions?
mac 'it's bad' gyvr
MWC President / President
It's always a good time to join or renew your membership!
My idea of a perfect vacation is a road trip through beautiful country. To make it really fun, all that's needed is a modified vehicle, a few close friends, and some serious off-roading. Cole Quinnell - Editor, 4WOR, Dec 99
Old August 30th, 2018, 04:40
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Re: TJ exhaust
mac 'it's bad' gyvr
Is it the same between 4 and 6 cylinder? I have 4 cylinder exhaust.
Old August 30th, 2018, 11:30
macgyvr's Avatar
NAXJA Member #120
Re: TJ exhaust
It's different I believe. And you won't ship big stuff
I did find this:
https://www.carparts.com/details/Jee...E&gclsrc=aw.ds
seems to be what the doctor ordered...
mac 'maybe' gyvr
Old November 14th, 2018, 23:10
tm8chris tm8chris is offline
Re: TJ exhaust
Check out also ebay for cheap yet quality exhaust kits.
Old November 15th, 2018, 00:30
macgyvr's Avatar
NAXJA Member #120
Re: TJ exhaust
She ended up buying the crown kit and a flow master. I put it on a couple of weeks ago after I got back from Moab. Worked out really well.
mac 'the TJ is much more enjoyable to drive' gyvr
Rate This Thread:
XJ JEGS Exhaust, Stock Exhaust, No Exhaust, Video 96Sportxj Modified Tech Discussion 5 March 12th, 2019 10:28
Does an exhaust gasket leak smell like exhaust? SuperRA OEM Tech Discussion 9 September 24th, 2013 16:23
heat/leak exhaust/new exhaust. TheManch Modified Tech Discussion 5 May 27th, 2004 17:28
