master engine rebuild kit
imma honky
Augusta, Ga
is $580 to high? Should I keep shopping around? I plan on rebuilding the engine in my 90 this summer.
This is a pep boys price. Should I try to do the transmission at the same time? or just take it to a shop?
cherokeepimpin said:
whats includedwith the kit?
not exactly sure what all is included, i will find out tomorrow (just got the cost today),
if you feel that you could rebuild the tranny, go for it, but the are easy to f-up
That's the same thing I was thinking, they are easy to screw up on, whereas the engine is mainly seal replacement.
When I priced Master kits for the 2.5 $450-$500 was about average. Have you checked with ww.Northernautopart.com? When I was looking they have the best price. 307.46 with NAPA comeing in second. However I did not get either so I do not know what is in them nor what the quality is like. They list the 4.0 87-90 for $413.00. Maybe one of the guys that has rebuilt their 4.0 will chime in.
Aight, here goes. These kits are from Advance Auto(Kragens?)....
$426.88-Cam/Lifter Kit
Camshaft Bearing Set
Cast Piston
Gasket Kit
Oil Pump
Premium Piston Ring Set
Timing Set - 3 Pc.
*Master Kit w/o Rods & Mains (w/Premium Rings)
*Freeze Plugs not Included
*1 Yr Replacement
$414.88-Cam/Lifter Kit
Cast Piston
Connecting Rod Bearing Set
Gasket Kit
Main Bearing Set
Oil Pump
Timing Set - 3 Pc.
*Master Kit(w/Premium Rings)
*1 Yr Replacement
$412.88-Cam/Lifter Kit
Cast Piston
Gasket Kit
Oil Pump
ECONOMY Piston Ring Set
Timing Set - 3 Pc.
*Master Kit w/o Rods & Mains (w/Economy Rings)
*1 Yr Replacement
$398.88-Cam/Lifter Kit
Cast Piston
Gasket Kit
Oil Pump
Economy Piston Ring Set
Timing Set - 3 Pc.
Main Bearing Set
*Master Kit(w/Economy Rings)
*1 Yr Replacement
$378.88-Cam/Lifter Kit
Gasket Kit
Main Bearing Set
Oil Pump
Timing Set - 3 Pc.
*Master Kit w/o Pistons (w/Premium Rings)
*1 Yr Replacement
$364.88-Cam/Lifter Kit
Gasket Kit
Oil Pump
Main Bearing Set
Timing Set - 3 Pc.
*Master Kit w/o Pistons(w/Economy Rings)
*1 Yr Replacement
$324.88-Cam/Lifter Kit
Gasket Kit
Oil Pump
Timing Set - 3 Pc.
*Master Kit w/o Pistons, Rods & Mains (w/Premium Rings)
*1 Yr Replacement
$308.88-Cam/Lifter Kit
Gasket Kit
Oil Pump
Timing Set - 3 Pc.
*1 Yr Replacement
I think I know the obvios answer to this, but I still want input from those who have done rebuilds.
TIA!
