OffRoadOhio
- Roseville, Ohio
I have a set of FOUR 30-9.50-15 Mesa AP tires. Tread is around 6-8/32nds of tread. Two tires have inner tread wear from poor alignment. $50 for the set.
Dana 60 passanger INNER axle shaft from a 2003 f350. $50
Also have a 1990 xj with 4.0 auto and np242 tcase. Jeep has 230+ thousand miles on it but runs and shifts great.
It has 4.5" front lift coils with adjustable upper control arms and fixed tubular lowers.
Front axle is a high pinion non disconnect dana 30 with 297 u joints. Calipers, rotors, pads, and wheel bearings are new. BRAND new lock right locker. Rugged Ridge HD tierod. Stock 3.55 gears.
Rear has a bastard spring pack using s10 leafs. swapped in 29spline 8.25 with welded carrier and stock 3.55 geaing.
4- 2 month old procomp lift shocks.
4, used 33" dunlop mudrover tires. fronts have about 8/32nds of tread, rears have 4-5/32nds. Spare is a General Grabber ats with around 4/32nds of tread.
Crager soft 8 wheels.
Has had, transmission fluid (aswell as a newe filter), powersteering fluid, and brake fluid professionally flushed.
Fresh oil change and dif fluid.
Body is very rough, it was laid over on my last wheeling trip, some glass is missing and windshield is cracked.
title is clear and I typically drive it to and fromt he trails and on weekend.
Could be drivne home at BUYERS OWN RISK. not only does the lift make it handle differantly on road than a STOCK jeep, the welded rear axle also makes it handle differantly.
$2000
All items located in ROSEVILLE OHIO 43777
I COULD ship the axle if you pay for it.
$2000
