Injectors
DVM04
Northern, NJ
I just got a set of fuel injectors out of a 2000 explorer that are 21 pounders. the number for them is XL2E, Think they fit rangers also with 4.0......Anyone using larger than 19 lb injectors from the mustangs, wonder if I can use them....Thanks
Five Oh motor sports recommends the larger 21+ injectors with modified 4.0 Jeep motors, modified being modded intake and exhaust for a start and strokers for the next stage.
I just put the 19lb bosch II's in my new motor, so far so good.
I ran 21 lb injectors for two months and runnined my plugs and had the worst gas milage in the jeep unless you get an adjustable map sensor it is just going to mess stuff up.
