I have the complete Renix fuel injection system off a 1990 XJ motor. It will run any 4.0L motor that uses this simple system, and you could also use it as a simple Fuel Injection Conversion on an older 4.2L motor. Just use this manifold and injectors, hook up the needed sensors and wiring and distributor. Also needs the CPS on the belhousing or dampener (Not Inc) and may need other sensors and stuff.
I can try and answer any questions, but i'm not a FI expert.
This motor DID run before it was taken out.
$700 for:
Intake Manifold
Fuel injectors and rail
Plug in harness wiring
Distributor
Renix computer
I have the 4.0L block if someone is interested too.
$700 for:
Intake Manifold
Distributor
Renix computer
