Shackle relocation
DutchVDub
Milliken, CO
So today I finally got started on my shackle relocation. I used a write-up I found on Pirate as inspiration. http://www.bsfab.net/?p=71 <---- That's the write-up.
I'll let the pics do the talking.
Frame on jack stands and axle at full drop, the tires are just barely above the ground
I Austin Powers'd it in
Shackle angle at full drop
Leafpac at full drop
My dented shock
the shaft is bent on it too
How the spring sits with all the weight back on
static hang, no axle pulling it down
Laying on the ground
Where those big military wraps hit the floor inside the front spring mount
measured on groung at 48.25"
Where I would ideally want the shackle to sit (measures 52" from eye to eye between shackle and front spring mount)
Started removing the flared out portion of box
test fitting
I had my helper with me today
mocked up and tacked together
welding it together
I didn't like the look of the first bead so I ran another next to it to make sure
decided to practice vertical welding
welded my tabs on (thankyou SpiderTrax)
Made a hole
mocked in place
removed the lower to springs from the pack
with the vehicles weight back on it
Now I just have to do the other side, but that'll have to wait for tomorrow.
Any plan to add gusseting to the sheet metal, or going to fill in the plug welds and call it a day?
If you want it, I'm about to throw away a perfectly good gas tank. LOL
the factory shackle bolt, 5 plug welds, all the edges welded, and a piece of 1.5" .120wall tube comin up through the floor. the tube is welded to the floor and once i snag some plate i'll also weld it to a platew that will the be welded to the floor.
True, true!
I never thought about it that way, but you probably have some weight savings as well: What is it...5lb/gallon???
finished it up mostly.
here is the tube coming up through the floor and welded. i'll be taking a piece of plate and drilling a hole in middle of it to weld the tube to and then weld the plate to the floor as well.
Here is how it sits
And the shackle box
Good job brutha! Looks like it moved your rear axle back some.
Shouldn't have - technically impossible unless he moved the centering pin or the hole it sits in in the spring perch. The distance from the front spring eye to the centering bolt didn't change nor did the distance from the centering pin to the rear spring eye.
I think it's the way his flare is mounted that gives that illusion.
When the spring flattens out axle has to move backwards since the front perch is non moving. It is a good thing gives a little more wheel base. But those are rustys flares...:D Dang I said the R word again...:shhh:
actually the axle is back more because the TNT u-bolt eliminaters have 3 center pin holes for different axle positions and I remounted the axle on the holes that push it farthers back.
Heh, heh........ so 'Stang and I were both right....... :thumbup:
