Old December 26th, 2007, 15:46
GhostDakota's Avatar
GhostDakota GhostDakota is offline
CB Radio & Antenna Mount Photos - Post Up
Just post up for your photos.. I'm always interested in seeing how others mount their CB's. Thanks to Begster for the idea on my current mounting setup which works very well:
Current (Antenna):
Former (Antenna & radio):
Old December 26th, 2007, 20:44
1996cc 1996cc is offline
Re: CB Radio & Antenna Mount Photos - Post Up
You've been around here long enough to know there are MANY threads already that already asked for the exact same thing.
Old December 26th, 2007, 20:55
splitz's Avatar
splitz splitz is offline
In his defense, there is only so much you can cover about mounting CBs and antennas. Instead of digging up old threads, sometimes you have to start a new one to get some fresh ideas and input.
Besides, I'll take any opportunaty to show off some of my install work! So here's mine!
Here are some pics of my install. I decided to use the cigerett lighter space for the plug, which worked out really well cuz I used the power and ground from the lighter. I may try to make some sort of bezel for the plug to make it look more OEM. Oh, one thing I should point out is Cobra screwed up the plugs for the handset and hideaway module. To make it easier, you need to switch the plugs around.
Some of the antenna. Write-up here
Old December 26th, 2007, 21:02
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Wheres the radio ant.?
Old December 26th, 2007, 21:12
splitz's Avatar
We don't need no stinkin radio antenna!
I've been meaning to get a second mounting OEM bracket for the other side or put in a "hidden" antenna, just haven't got around to it. I listen to my Garmin most of the time anyway (while she does talk sexy to me, it also plays MP3s)
Old December 26th, 2007, 21:34
mojojojo's Avatar
mojojojo mojojojo is offline
i gotta say i'm diggin this concept. hmmmm.......
1 ? though.....how sturdy is it once it's mounted ? will it hold up to trees on the trail etc....?
and where is the c.b. ? Edit: oops, just noticed its one of those in the mic jobbies.
Old December 26th, 2007, 21:37
Lowrange2's Avatar
Member# 2368
I need an antenna! My garmin gets on my damn nerves runnin its mouth all time! It stays muted while I run my ipod thru my radio.
Old December 26th, 2007, 22:49
XCastleXJ XCastleXJ is offline
wow, i really like the lighter idea. ive wanted a cb in my jeep for a long while now but every other install i have seen makes it look too cluttered up front. nice job
Old December 27th, 2007, 05:46
splitz's Avatar
I can't take all of the credit. I got the idea of using the Cobra 75 from 53guy, and the antenna mount from Sting25.
As far as sturdiness, the antenna is a fiberglass whip, that gets whipped around pretty good. I could have also used a spring base, but I found that the flex antenna works good enough.
Old December 27th, 2007, 06:22
I figured I'd start a new one. People are changing CB's constantly. If you do a search for CB radio's, there's only a couple posts, most aren't recent (or are locked). I did my installation due to a reply in a similar thread that got locked, so if that helped me, this can help others as well IMO.
Old December 27th, 2007, 08:13
wingnutooa wingnutooa is offline
On a Time Out
i'll post some pics when i get back into town but it's up top between the visors.
its a nice spot for it keeps it out of the way and very audible.
the antenna i just ran an angle bracket off the rear quarter by the hatch and a spring. that way i could tether it forward to the rack that i dont have yet. (for parking in the garage)
Old December 27th, 2007, 08:20
goodburbon's Avatar
goodburbon goodburbon is offline
I don't leave mine in all of the time. I have a mag mount antenna that I throw on the roof when I go wheeling and I cram the radio between the passenger seat and the center console. Stays put good enough and it's easy as pie to yank it out when I don't need it. (so it won't get stolen)
Old December 27th, 2007, 13:40
huntersteve61 huntersteve61 is offline
does anyone know of a bracket to mount the cb antenna to the rear taillight? i've seen them made for explorers not sure on an xj, where would one suggest an easy mount? bumper?
Old December 27th, 2007, 13:50
We sell rear light mounts for CJ's, YJ,'s, TJ's, but nothing for XJ's. We do sell universal XJ ones:
http://www.quadratec.com/products/96080_55.htm
Old December 27th, 2007, 14:35
Frankkl's Avatar
Frankkl Frankkl is offline
Radio Antenna Connectors NON-STANDARD? Rick Anderson OEM Tech Discussion 12 December 6th, 2008 09:17
Quality Budget CB Radio & Antenna fubar XJ Modified Tech Discussion 18 January 3rd, 2008 11:51
radio antenna imwally OEM Tech Discussion 6 December 25th, 2007 19:16
RADIO ANTENNA options ? generalleexj Modified Tech Discussion 6 January 26th, 2005 14:41
Radio Antenna for MP3 BSD OEM Tech Discussion 15 January 1st, 2005 06:40
