Old February 27th, 2006, 08:30
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
1/3 seat in the back
Since I ussually carry my tools behind the driver seat and want as much extra packing room as I get get I decided to make my XJ a 3 seater. Nope, it's not another rear bucket seat project. It's a split bench project.
I started with a regular seat and trimmed it a bit. Then I have made a bracket/hinge and test fitted it inside.
Since all seems to fit, now all I need to do is get it upholstered.
Old February 27th, 2006, 09:07
CartsXJ's Avatar
CartsXJ CartsXJ is offline
Re: 1/3 seat in the back
I have thought of doing this so many times. After I saw it in my moms GC, the idea has been brewing in my head. Did you make the inside bracket from scatch or modified one? Nice work. Could you just use have the stock cloth and sew it up?
Old February 27th, 2006, 09:11
Kejtar's Avatar
PostMaster General
The inner bracket I made from scratch. It was fairly simple to do so:
1. take some angle iron
2. make an incision in one side to bend it in, to match the angle of the other bracket, weld it up
3. make an incision further down to bend out, fit a piece of steel in the opening and weld it up
4. drill a hole more or less in line with the other side
5. take a bolt, cut of the head, round it up fit one nut on one side, put it throug the hole in the floor and tigten it up from underneath
6. take big visegrips, grab the bolt from the inside and bend it down a hair (because of the shape of the tunnel the bolt points upwards too much but you can push the whole thing down).
Upholstery... yup, I'm hoping I could reuse the old piece to keep the cost down.
Old February 27th, 2006, 09:17
esrasmu2001's Avatar
esrasmu2001 esrasmu2001 is offline
Looking good. To bad I can't give up seating area. Having three kids that like to go out as much as you do kinda hinders things.
Old February 27th, 2006, 09:19
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: 1/3 seat in the back
no one rids in my backseat anymore---
the seat is right next to me in my dorm room...
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old March 11th, 2006, 11:14
Kejtar's Avatar
PostMaster General
it's done
http://kejtar.com/XJ/tech/bench/DSCF3802.JPG
http://kejtar.com/XJ/tech/bench/DSCF3801.JPG
http://kejtar.com/XJ/tech/bench/DSCF3800.JPG
Old March 11th, 2006, 11:56
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
What are you doing about the back of the seat?
Old March 11th, 2006, 11:59
BIGSLVRXJ BIGSLVRXJ is offline
Thumbs up Re: 1/3 seat in the back
That looks swanky Remi. Nice Job!
Old March 11th, 2006, 12:00
Kejtar's Avatar
PostMaster General
Gonna keep it as it is for now. My primary motivation was to be able to stack things behind the driver and stick a center console thingy in the middle.
Down the road though things might change a bit and I'll split the back seat in two as well. Problem is though that there isn't really any good way to support it and because of the way XJ back seat is designed the back part can't stand by itself if it's split in half as it's supported across but.... I'm keeping my out in the junk yards for a ZJ/WJ with a split bench. IIRC ZJ would fit better but WJ still is doable with slight modifications.
Old March 11th, 2006, 12:20
jmaxj's Avatar
jmaxj jmaxj is offline
you acctually think people are gonna ride with you c'mon remi you should know better
Old March 11th, 2006, 12:26
Kejtar's Avatar
PostMaster General
Remember the three stooges?
Old March 11th, 2006, 13:55
jonboy's Avatar
jonboy jonboy is offline
Remi - got a pic of the whole back seat area?
Oh - Happy Birthday too!
Old March 11th, 2006, 13:57
Kejtar's Avatar
PostMaster General
No, that's all I got at the moment. I'll try to take one for you later. Do you want to see the whole area where the bench originaly was?
Old March 11th, 2006, 14:02
jonboy's Avatar
yeah...I'd like to have a split bench so I can haul more crap on long trips, like on the Dusy, but still sleep back there when I'm too lazy to put up a tent, which is most of the time
some help with lift stewie Intermountain Chapter 8 November 14th, 2005 17:35
How high should the front be in relation to the back? Double Down Modified Tech Discussion 10 July 13th, 2005 12:40
Back Up Lights - Not NSS coach9119 OEM Tech Discussion 4 January 29th, 2004 13:22
Back from Moab..... CRASH 2003 20th Anniversary Celebration! Moab, Utah 9 October 14th, 2003 05:38
