Old July 31st, 2019, 13:34
RCP Phx RCP Phx is online now
Re: Overheating solved
While flow could increase with Rpm's, the pressure is constant based on the system cap. What can be reduced is the cavitation in the system. When the t-stat is closed the water has no place to flow and the pump is still trying to "put-out" causing cavitation. In the case of companies claiming higher flow rates, what is that based on?
Old July 31st, 2019, 13:49
Greenspan's Avatar
Greenspan Greenspan is offline
Well there is a pressure differential in the system across the pump which causes the flow of coolant.
I see what you are saying but shouldn't the thermostat be open if you are having overheating problems? I can see this causing the jeep to heat up faster but with a properly operating cooling system once at operating temp the thermostat should open to control the temp.
Old July 31st, 2019, 16:18
Yes there would obviously be some pressure differential across the pump, but it can't be much. I think that would be the proper way to test pumps.
overheating at freeway speeds issue still not solved!!! AZRockRunner Arizona Chapter 41 June 17th, 2007 01:18
'91 XJ HO NO SPARK SOLVED TXRIVERRAT OEM Tech Discussion 19 December 18th, 2006 21:15
Solved Overheating Problem BigReady Modified Tech Discussion 0 August 11th, 2005 11:56
Overheating is not solved robs Modified Tech Discussion 64 July 3rd, 2005 17:02
I think I solved my overheating issue! GottaBeJeep Modified Tech Discussion 7 June 14th, 2005 19:33
