RWKHausSupply
- yorba linda, Cali
Warn 45880 - Warn M6000 Self-Recovery Winch
M6000 SPECS/PART NUMBERS
Warn Part Numbers: PN 45880 CE (12V DC)
Rated Line Pull: 6000 lbs. (2720 kgs) single-line
Motor: 12V 4.8 hp, Series Wound
Remote Control: Remote switch, 12' (3.7m.) lead
Geartrain: 3-Stage Planetary
Gear Ratio: 156:1
Lubrication: Aeroshell #17
Clutch (freespooling): Sliding Ring Gear
Brake: Automatic Direct Drive Cone
Drum Diameter/Length: 2.5"/9.0" (6.4cm/23cm)
Weight: 74 lbs. (34 kgs.)
Wire Rope 80', 5/16" diameter (24m, 8mm diam.)
Fairlead for PN 45880
Recommended Battery: 650 CCA minimum for winching
Battery Leads: 2 gauge, 72" (1.83m)
Finish: Argent Gray Powder Coat
Nuts/Bolts: PN 39625
CE Winches: CE products are designed to meet European Standards. CE winches include CE labels, manuals, roller fairlead, safety hook and thimble.
Robert
RWK Haus Supply
Gear Ratio: 156:1
Robert
RWK Haus Supply
