Spring Meet and Greet Swap Meet
Mr.Shrek
Murfreesboro, TN
Due to some interest in adding a swap meet to you meet and greet, I throwing this thread up for those of interest. I'll kick it off with the parts I'm interested in selling.
2 pairs of manual front doors both black with manual windows and locks. One door has a slight dent in the middle of it (Passenger Door). If anyone is interested in the doors and would like a pick I will nab some and email them to you. $25 each.
Computer from a 91 cherokee 4.0 ho $20
Passenger tail light: $20
Stock rear leaf shackles: $5
Full gray dash board, good condition from a 91: $20
2wd AW4 tail shaft housing: Free
2 4wd AW4 computers: Free
Stock front and rear sway bars: Free
Post up what you would like to unload.
Nevermind then, but thank you. And if anyone else coming has a set of 97+ fronts laying around then let me know!
Heres my giant parts list, if your interested in something let me know, everything needs to go, so make an offer, id rather sell it for pennies then scrap it.
for 97-01 XJ:
-231 shifter bezel
-auto trans shifter bezel
-Fog light switch, defrost switch, rear wiper switch and some wiring
-grab handles (medium grey)
-sunvisors without mirror (medium grey)
-battery tray w/ sensor A+ condition
-radio/HVAC bezel
-231 shift decal (the one from headliner)
-rear soundbar speakers and covers (medium grey)
-front license plate holder (x2)
-rear bumper endcaps black
-front wiper arms
-front pass side power door lock and outer handle
-02 sensor, 4wire with black connector
-front door speakers
-231 shift linkage
-front door triangle trim (x2)
-rear driveshaft #52098732 (auto trans 4wd ?)
-98 owners manual (x2)
-98 light grey seats front 2 and rear bench
-radiator, manual trans
-a/c condensor (x2)
-98 rear doors with manual windows
-electric rad fan (2000 XJ)
other XJ parts:
-towhooks pair (no brackets)
-94 header panel
-shock boots, blue (x4)
-stock track bar
-stock leaf springs
-stock coil springs
-rear shocks monroe, stock height new in box (x2)
-8.25 u-bolts regular
-8.25 u-bolts extended
-ubolt plates (x4)
-ZJ sunvisors from a limited with homelink on driver side
non jeep stuff:
-pioneer cd player DEH-P3600 (like new in box)
-2000 watt amp w/ some wiring
-2 15" MTX thunder 8000 in box built to fit in an XJ, 1000 watts each
im sure ive got alot more stuff, also i have a 8.8 w/4.10 LSD up for grabs $350
Looks like ChuckstrPT (Andy) and I will be making it up to the M&G. :guitar:
KGB416, im interested in a 231 shifter bezel if you still have it.
trail rate this, what dose a 60mm TB run these days $?
Lets see... What do I have...
-Rear black leather seat out of a 89 Limited XJ. Its in very good condition. Only one little puncture on the seat bottom twords the back.
-Rustys adjustable Lower control arms.
-RE1600 Adjustable track bar with stock track bar mount.
-97' ZJ OHC with bracket (grey)
-(8) yellow top ford fuel injectors, used.
-Passenger side grey seat out of a 98' XJ perfect condition.
-95' D30 hub bearings (almost new).
-Stock rear DS
-Stock NP231 main shaft and tail cone
-Stock transfer case skid
-Stock shackles
-D44 Superlift eXtreme Differential Cover Ring
-Pre 97' Ebrake cables
