project clean up
builtit
oceanside
im cleaning up the garage as i try and finish up my project.
2" AAL springs with stock shackles 40$
fender flares(white, beat up..still attached to the fenders/ i cut)get the out of my yard with a 6 pack?
roof rails(stock) kinda beat up(maybe you need a spare?) 6 pack
stock cluster(idioit light) free
stock single diaphram brake booster with master attached(good booster
prop valve with lines(good to modify for rear disk) 5 bucks
stock bumper brackets 10 bucks
stock crossmember(aw4) 5 bucks
renix pressure bottle(no leaks) 10 bucks
electric fan(stock ac) has cracked tabs...but you could make some metal ones? 10 bucks?
soon will have a disco HP30 complete with 3.55 gears
D35 3.55 gears....NON c clip (early) brand new dums and shoes hardware..never driven on after rebuild..swapped in a 8.8
