RWKHausSupply
- yorba linda, Cali
For a limited Time:
For either high pinion Or low pinion Dana 30:
Spartan Insert locker.
This locker requires no added setup. Can be installed by most enthusiast, in their driveway, in less than 3 hours.
Comes complete with hardened cross shaft and is the most simplest install of any insert locker.
And you get a front 4340 Chromoly axle kit, that has a 5year warranty on the axles. As well as a pair of Spicer 760x hardened Ujoints. Includes 2 piece block off kit with inner axle seals even.
All you need is gear oil and a few hours, to make your Jeep perform like it should.
Go Here to order
Only From:
RWK Haus Supply
Please email, text or call with any discounted drivetrain needs.
714-875-2414
[email protected]
Go Here to order
Only From:
RWK Haus Supply
714-875-2414
[email protected]
