Old January 21st, 2006, 15:28
canadianwheeler canadianwheeler is offline
Which speedo gear part # ? short or long shaft?
I have a 92 xj with 31's and just finished installing 4.10s. I want to change my speedo gear but neither I or the parts guy at the local dealership and figure it out. I know i need a 39 tooth gear or close to it.
I did a little searching and came up with this :
Long shaft part numbers (1991-1993) - 2538939 - 39 tooth speedo gear
Short shaft part numbers (1993-2000)- 52067639 - 39 tooth speedo gear
I took a look at my t-case and it seems that i have the newer electronic type of connection which mean i should have the short shaft? But with my year it says i should have a long shaft which is a cable type?
Make sense? Any ideas which one?
Old January 21st, 2006, 19:02
hippymill's Avatar
hippymill hippymill is offline
Re: Which speedo gear part # ? short or long shaft?
did the t-case get swapped out at some point? 92 should require a long shaft. easiest thing to do would be to pull the gear you have and visually confirm if its a long shaft or short.
Old January 21st, 2006, 19:28
Nope stock t-case. I was reading somewhere else that the electronic type connection first came out in 91?
Old January 22nd, 2006, 17:10
tttt
Old January 22nd, 2006, 18:14
METAL MONKEY's Avatar
METAL MONKEY METAL MONKEY is offline
take a look at this. it should tell you everything you need.
http://go.jeep-xj.info/HowtoSpeedoGears.htm
"Do or do not... there is no try", Yoda
Old January 22nd, 2006, 19:37
thanks but that still does not help. According to that mine should use a speedo cable but mine has electronic type.
I need to know if all electronic type use short shaft or not?
Where to buy speedo gear? Not the dealer Bounty Hunter OEM Tech Discussion 4 October 19th, 2005 16:31
Wanted: 33 Tooth Speedo Gear blaisetd Wanted: Private Party Only 0 March 3rd, 2005 10:39
SPeedo gear XJeeper05 Modified Tech Discussion 9 October 22nd, 2004 08:57
98' XJ speedo gear frustration shimmy Modified Tech Discussion 16 September 20th, 2004 11:18
Teraflex short shaft kits North Atlantic Chapter 0 January 9th, 2003 05:30
