jeepster_259
- West Palm Beach, FL
So, I just put in an auburn ected locker in my d30. I installed a diff cover from a low pinion d30 because it already had the electrical plug installed in it. My 98 is a high pinion d30. Well. After installing the cover, I noticed that the fill/drain plug is 1" lower than my high pinion cover.
Will this be a problem in not allowing me to run enough diff fluid or will I be ok? I just don't want to go through the PITA off having to install the electrical plug in my old diff cover and all that crap if I don't have to.
