OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
'96 4.0 Injectors
I've searched and I'm still confused. I've got a leaky injector so I'm going to replace them all. I've read a bunch of threads about using Ford 5.0/4.6 injectors, but I can't tell if that's only for the Renix engines. I looked on 5-0 motorsports and they only list the 4-hole injectors through '93. If anybody has bought 4-hole injectors for their '96+ 4.0 could you please give me the part number you ordered and where you ordered it from?
Thanks. |
#2
Re: '96 4.0 Injectors
I bought the fuel injectors for my 92 MJ from this guy. He also has injectors for a 96-98 4.0.
http://precisionautoinjectors.com/pr...3&productId=11 He also sells on eBay at a better price. |
#3
Make sure your '96 is really a '96. I have a '96 Country, made in early '96. My son has a '96 Classic, and when he got it a few months ago, I noticed that the fuel injectors , as well as other things, were a little different. Turns out that some of the later '96 models had mostly '97 running gear, with the older body. His was manufactured in Sept. of '96, well after '97 models would have been in production. I don't know the exact date of changeover, but I don't think '97s showed up at dealers until January of '97.
#4
Thanks for the replies. According to the link above the injectors are the same for 96 - 99
#5
The 96-99s had the gray top 23.2# injectors. I have a used(75K) set sitting in the shed. . .
#6
I ordered six of the F5TE-24lb injectors from Fiveomotorsport.com back in 2004 - no problems with ordering, or with the injectors afterward. This is on the stock 4.0L in my '96, no stroker or any engine mods other than a '99 intake manifold added earlier this summer.
Jim www.yuccaman.com |
#7
I too am running the gray top injectors from 5.o motorsports,No problems with them but the wire connections have loosened a time or two,I just used plastic wire ties to hold the connection tight.
That may be due to the age of the wires and vibration . Wayne
Wayne Member#17 NRA Life member, AARP NovaJeepers 96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s |
#8
Thanks again for all the replies. For some reason I thought I needed 19lb injectors.
#9
I don't think you even need to spend that much $. Only the Renix injectors are problematic.
Buy a new set of o-rings top and bottom and save the cash. |
#10
The O-rings are only a year old, so I think I've got another problem.
Thread Tools | |
Display Modes | |
LT1 Injectors | wolfpackjeeper | Jeep Street and Performance | 12 | February 25th, 2008 10:21 |
injectors | SUA SPONTE | OEM Tech Discussion | 7 | March 21st, 2007 09:49 |
99 Injectors | jeepboy_90 | For Sale: Private Party Only. XJ ITEMS ONLY | 0 | November 17th, 2006 17:02 |
Renix Injectors for Mustang Injectors | buffalomatt350 | Modified Tech Discussion | 1 | September 7th, 2004 12:44 |
GM Injectors? | DPC | OEM Tech Discussion | 5 | January 30th, 2004 23:27 |
