Roger D
- Clemson SC
Is the 4.0 head from a 1999 Grand Cherokee the same as the head on a 1999 4.0 XJ?
Roger D said:Is the 4.0 head from a 1999 Grand Cherokee the same as the head on a 1999 4.0 XJ?
XJRubicon said:Strange... our 99' XJ has a distributer... I didn't think the coil rail was till 00' on either the XJ or WJ.
XJR
JNickel101 said:x2, 99 for WJ and TJ, 00 for XJ....
i suppose there could be some really really late model 99s with a coil pack...? who knows...
Roger D said:My sons XJ is a 2000 model. I was just curios if the 99 XJ and WJ heads were the same. I pickep up the complete motor today for $30 complete with a big hole in the block where it threw a rod. It does have the coilpack head 0331 I assume. I will try to look and see the differance in it and the 2000 XJ motor tommorow.
Roger D said:I appreciate the info 5-90. I was probably not clear on the earlier post. My 2000 XJ has the coil packs /DIS with no distributor and so does the Grand Cherokee motor. The head is supposedly good on the G Cherokee motor. Even if the head turned out to be bad the intake,coil packs, throttle body/fuel rail and exhaust manifolds should make it worth what was paid for it.
