Old September 29th, 2006, 07:42
HogWash's Avatar
HogWash HogWash is offline
Pre runner
I would like to set my XJ up for pre runner any one have any ideas?I love speed and I love my XJ.I started doing a little bit of unorganized circle tracking down in FL. and I loved it but my suspension couldnt take it on my 04 wrangler(which was a lemon by the way) and blew out the stock shock.Yes I do have an XJ now my buds convinced me to get one so here I am
Old September 29th, 2006, 08:07
88flexj's Avatar
88flexj 88flexj is offline
Re: Pre runner
jeepspeed.com
Old September 29th, 2006, 08:09
HogWash's Avatar
Re: Pre runner
Originally Posted by 88flexj
jeepspeed.com
Ive checked there a couple of times and was looking for suspsion set ups ....no found
Old September 29th, 2006, 09:59
Skullver's Avatar
Skullver Skullver is offline
Still Flailing
Re: Pre runner
if you are going to build one, do a long arm 4-link, if you are in the market for one, Full Traction 6" long arm kit is a good start. You will need some high bucker shocks and you will need to get rid of all the stock shock mounts. There are many many things that should be done if you will be hitting rough terrain at speed and expect your xj to survive. A cage is mandatory for safety and also to stiffen the unibody, I have already cracked two windshields from the flex. PM me if you would like to discuss this further.
Old September 29th, 2006, 10:40
twisted_ed's Avatar
twisted_ed twisted_ed is offline
Re: Pre runner
I am curious.. is there a difference between long arm setups, I always thought long arms were the same as REs long arms but full tractions dont appear to have the upper control arm mounted to the lower one radius arm style? is one style superior to the other?
Old September 29th, 2006, 10:52
Skullver's Avatar
Still Flailing
Re: Pre runner
I wouldn't say superior, they are more application specific, the full Traction stuff could be used for crawling, but is is designed more for the high speed stuff. The radius arm stuff, like RE or tnt, are more for crawling. they have different behaviors at speed. The radius arms kits ,the castor changes significantly through out the suspensions travel, where the four link doesn't.
Old September 29th, 2006, 11:08
Matt S. Matt S. is offline
Re: Pre runner
I don't want to sound like an "know it all" cuz if you know me you know I don't know anything at all. So with that, I truely believe this is one of those things, if you have to ask... you shouldn't do it. If you really want to learn how do build a runner, the first thing you need to do is go out and do it. Go take the stocker out for a little cruize, then come home and fix whatever broke and ask yourself "what could make it better for next time?" Then do it again and again and again. Now that is the truth.
Now if it were specific or super technically related, I bet we (those with a little experience or knowhow) could help.
Old September 29th, 2006, 13:47
Goatman's Avatar
Goatman Goatman is offline
Re: Pre runner
There are varying degrees of pre-running........since pre-running has become a sport in itself. A full on pre-runner can be expensive and very well built, but moderate pre-running can be done with an XJ if attention is paid to strengthening suspension and shock mounts, getting a stiff front spring, good shocks, and good bumpstops.
What type of actual use and terrain are you looking at?
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old September 29th, 2006, 13:59
Pharaoh XJ's Avatar
Pharaoh XJ Pharaoh XJ is offline
Re: Pre runner
what about desert raids ? we have this XC rally in Egypt similar to Dakar http://www.jvd.it/rally/rally_online...o_iscritti.php
couple of egyptian guys are competing with XJs. The track is mostly sand dunes and some rough terrain which would be the best setup?
Long or short arm ? 4 link or radius ? and how much lift would you recommend?
Pre-Runner Bar macs97XJ Colorado Chapter 7 February 1st, 2006 16:30
Pre-runner fenders Stick Modified Tech Discussion 8 April 21st, 2004 23:11
Pre-runner clip.... jmaxj Modified Tech Discussion 8 January 30th, 2004 13:18
rough runner Tom Campbell OEM Tech Discussion 1 October 9th, 2003 14:32
toyota 4 runner MauriceGOL Non-Tech / Off Topic 9 September 30th, 2003 08:38
