Old December 10th, 2007, 12:18
ehall's Avatar
ehall ehall is offline
need build/budget advice for gear swap
The 91 beater I got has D30 up front and a C8.25 in the rear, with a 3.55 axle ratio. The axle should be strong enough for my needs (towing construction equipment and materials through mud basically), but I will need to regear to 4.88 in order to have enough torque for towing with larger tires.
I have no experience in this part of automotives. What do I need to get, what kind of budget am I looking at, etc? Would it just be easier and cheaper to go with junkyard D44 front and F8.8 rear?
Thanks for any help
Old December 10th, 2007, 12:25
89xj 89xj is offline
Re: need build/budget advice for gear swap
8.25 can only be geared up to 4.56, they dont make 4.88 for the 8.25
Old December 10th, 2007, 12:28
ehall's Avatar
Well that sucks. Alright it looks like that 4.56 would give me "near factory" with 35" tires so even though it is less torque than I want it would be adequate (another argument for the F8.8 though). What am I looking at for that?
NOT a budget buggy build Goatman Advanced Fabrication and Engineering 450 October 28th, 2008 00:00
Streetable trail rig budget build take 2 WTF South East Chapter 38 February 29th, 2008 18:25
Wife ok's a budget for my xj build Gerr SoCal Chapter 10 May 25th, 2006 09:37
Budget Boost advice please? (extreme budget!) montanaman Modified Tech Discussion 5 February 13th, 2006 19:07
how much lift from RE add-a-leaf? & budget build help. fordtech Modified Tech Discussion 0 August 4th, 2004 19:42
