Old April 13th, 2007, 19:35
cjben cjben is offline
engine swap: 96 4.0 auto engine where 92 4.0 manual tranny engine is
Soon i will be swapping an 96 4.0 into my 92 xj. I am not really worried about the electronics and sensors,I will just use my 92 stuff. my question is this: my 92 jeep has the 5 speed manual tranny and the 96 engine i will be putting in it was from an automatic xj. Can i just buy a pilot bearing for my 92 and put it in the 96,or will machining need to be done to the crankshaft to get it to fit the pilot bearing? I am hoping this is as simple as putting in a new pilot bearing. I will need to get the swap done as soon as possible once i get started,will not have time to take the engine/crankshaft in for machining if that is what needs to be done. thanks for the replies!! Ben
Old April 13th, 2007, 22:47
lawsoncl lawsoncl is offline
Re: engine swap: 96 4.0 auto engine where 92 4.0 manual tranny engine is
Napa shows the same pilot bearing for both years, so I think it's a straight swap. The end of the crank should already be drilled. I would highly recommend replacing the pilot bearing while you're in there since it's only $7.49 and a bad pilot can destroy the tranny input shaft (btdt). Maybe do the clutch too, depending on the mileage and condition.
Old April 13th, 2007, 23:39
5-90's Avatar
5-90 5-90 is offline
Swap the flexplate for the flywheel, install the pilot bearing/bushing (there should be none in the automatic, since the coupling there is rigid) and install 1992 sensors (the 1996 is OBD-II, and some of the sensors are different. I don't recall which ones.)
Yeah - pretty simple, since it's not a conversion.
Old April 14th, 2007, 12:24
thanks,I was hoping it was as simple as just putting a new pilot bearing into the crankshaft of the 96 engine
Old January 21st, 2010, 19:52
rcnerd's Avatar
rcnerd rcnerd is offline
Allright I'm going to revive this old thread:
So am I to understand that an engine from an auto or from a manual will fit into a manual?
I just picked up a manual zj (yes, seriously, a manual zj) with a buggered engine. can I install one from an auto without using custom pilot bushing?
Thanks!
Engine & Tranny Swap Ten30 Modified Tech Discussion 4 February 15th, 2007 00:15
Engine Mount Bolts Torn out of the Engine clean96XJ OEM Tech Discussion 9 January 6th, 2007 19:31
OBDII Engine Code Reader - Check Engine Light Diagnostic - NEW BigTP2 For Sale: Private Party Only. XJ ITEMS ONLY 1 December 19th, 2006 13:00
Seperating Engine from Manual Tranny desertred OEM Tech Discussion 2 March 13th, 2004 09:17
Mating Engine to Manual Tranny desertred OEM Tech Discussion 1 March 7th, 2004 23:50
