Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old July 29th, 2019, 16:24
CLSegraves CLSegraves is offline
Mounting Winch off-center?
I want to mount my Winch behind the front crossmember (under the radiator). However, if I center the winch, it hits the steering box. Is there any reason why the winch couldn't be mounted off-center towards the passenger's side?
Old July 29th, 2019, 18:23
old_man's Avatar
old_man old_man is offline
Re: Mounting Winch off-center?
Not really. A few inches won't matter that much. Remember as the line spools in, it weaves back and for on the drum several inches.
Tom Houston - Former Colorado Chapter Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old July 29th, 2019, 23:54
Thanks for the response. Does the fairlead need to be centered on the winch drum or can it be centered on the vehicle?
Old July 30th, 2019, 05:17
old_man's Avatar
Ideally on the winch.
Rate This Thread:
mounting winch on non-winch rigidco bumper wannabe Modified Tech Discussion 3 October 9th, 2007 21:33
Mounting the mobile solenoid winch pack...underhood or on top of winch??? Big Red Modified Tech Discussion 19 July 4th, 2006 08:43
CB mounting (center vent) kccherokees Modified Tech Discussion 13 November 8th, 2004 17:08
Winch Mounting (types of mounting) Lunatic728 Modified Tech Discussion 13 January 7th, 2004 09:03
synthetic winch line mounting on winch? Jeff 98XJ WI Modified Tech Discussion 3 July 27th, 2003 21:28
