Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old October 22nd, 2019, 15:39
Down under Down under is offline
Ring gear removal and reinstall
Can someone enlighten me as to the importance of the common practice of marking the ring gear to the carrier, when separating, and re-fitting it...
I can't imagine they are balanced in the factory assemble????
What are the issues of fitting a replacement ring gear to the carrier....
Newbie, but can't comprehend the I importance.
Totally understand the reason for thread alignment in the carriers bearing caps regarding orientation.
Old October 22nd, 2019, 16:04
SlowXj SlowXj is offline
Ring and pinions are matched sets for one... Shouldn't just change one or the other.
Old October 22nd, 2019, 16:20
Re: Ring gear removal and reinstall
Ok, thanx, but really just meant the ring gear it's self
Old October 22nd, 2019, 19:12
Are you talking about taking the ring gear off and putting the same one back on? If so when doing this you should mark the gear to put it back on the carrier in the same orientation. This is to ensure gear run-out stays the same. This isn't something everyone does and I'm sure that's acceptable but if it can help why not do it?
If you are talking about replacing the ring gear due to breakage or something the answer is different. The pinion gear would need to be replaced as well due to the matched set nature I mentioned in the prior post.
Old October 22nd, 2019, 20:47
old_man's Avatar
old_man old_man is offline
You ring and pinion have the tightest tolerances in the whole vehicle. If you take any part of it off, you need to do a full gear pattern check. Ring and pinions are not for inexperienced mechanics. They take special tools and tons of patience and experience to get adjusted correctly.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old October 23rd, 2019, 23:54
Cheers guys, yeah I was talking about re-fitting the same one.
I'm about to replace a carrier that I got the matching pinion for.
But I will leave the original pinion in and swap ring gears over to keep matched.
Old October 27th, 2019, 09:47
md21722 md21722 is offline
I have not specifically heard of "marking the ring gear to the carrier" but then again most people do not remove their ring gear only to re-install it on the same carrier.
When fitting the ring gear to the carrier, it should be spun in the housing and run out should be measured. If there is sufficient run out, installation guides have you turn the ring gear on the carrier to try to reduce runout.
Old November 6th, 2019, 04:33
old_man's Avatar
If you swap the carrier, you will have to do a whole new gear setup and will need to press off the bearings and re shim them on the new carrier. They will not be the same most of the time. This is a time intensive and PIA if you do not have the correct tools and even then it is a PIA.
Around here it will cost you a minimum of $200-$400.
Just swapping everything over is a crap shoot and I give you a 1 in 10 chance of not destroying your gears.
Old November 6th, 2019, 04:51
Yeah, it's on an 8.25. It was a bit of test of patience dialing it all in correctly before with the LSD carrier. But swapped over to open with a Spartan.
I just couldn't see the big fuss over putting the ring gear back on exactly the same bolt line up to the carrier.
Rate This Thread:
Ring gear reinstall Lurch Modified Tech Discussion 10 May 11th, 2011 17:30
NSS clean/reinstall, now no 2nd gear and CEL hxcjohnny OEM Tech Discussion 8 March 20th, 2011 06:02
ring gear carrier, bearing removal wingnutooa Modified Tech Discussion 8 January 8th, 2009 13:30
Ring gear bolts for D44 with thick gear set? stoneattic Modified Tech Discussion 1 February 13th, 2008 09:37
Fabbing a ring gear spacer ring? bretto Modified Tech Discussion 13 April 19th, 2006 15:16
