- Indiana-Missouri
I was going to eliminate my stock xj res, and just run a big aux resevoir I have, and was hoping that I'd be able to use some kind of adapter into the steering pump return port.....xj's have a pump-mounted tank with an o-ring, and the port is SMOOTH unlike other pumps that are threaded.......
so can I use both? can the stock res. "pull" return fluid through another res? Will there be a starvation/overfill problem?
thanks
thanks
