RWKHausSupply
- yorba linda, Cali
This is the deal of deals, going on right now in Traction and Strength.
Go here to see the deal of deals
FOR A LIMITED TIME $825
$1218 typical retail price.
AND THERE IS A $55 YUKON REBATE
When purchased before May 18th
you get:
Yukon Grizzly locker for Dana 30
Fits Dana Spicer 30 with 27 OR 30 spline axles - Select your needs from options 3.73 and up ratio only
Patented internal design reduces common locker failures 8620 internals for added strength.
Assembled in the USA 1 year warranty & Covers the replacement of the unit and any collaterally damaged parts and associated labor, up to $2,000.* *Collaterally damaged parts must be submitted for inspection.
$55 REBATE AVAILABLE TILL MAY 15TH.
The Yukon Grizzly Locker is the ultimate in mechanical locking differentials for street, off-road, and drag racing. Grizzly Lockers provide 100% power to both tires, while still allowing for disengagement while negotiating turns.
Technical Notes: This unit is double drilled for both 3/8" & 7/16" ring gear bolts.
AND YOUR CHOICE OF 27 OR 30 SPLINE 4340 AXLE KIT:
USA Standard 4340 Chrome-Moly replacement axle kit for TJ/XJ/YJ/WJ/ZJ front, Dana 30, 27 or 30 spline
Front axle kit Fits Jeep Wrangler and Cherokee front with Dana Spicer 30
4340 Chromoly axles 27 spline inner axles Includes inner and outer axle shafts with Spicer u-joints
Also includes block off kit for those applications with 2 piece axles on pass side.
5 Year warranty on shafts. Precision, quality USA Standard Gear axles. USA Standard Gear uses precision manufacturing technologies to provide top quality, competition tough axles.
Only From
RWK Haus Supply
Please email, text or call with any discounted drivetrain needs.
714-875-2414
[email protected]
you get:
Only From
RWK Haus Supply
714-875-2414
[email protected]
